No drive in any 727 trans position after Transgo install
Drove around the block - felt like it went into neutral and quickly popped back into gear couple of times - and overlap in Drive - forgot what gears.
Then when I put it in reverse to back into garage I lost all trans engagement - nothing.
It does show 1pt low - which I doubt would cause the control?
The overlap is band adjustment I assume.
I'm not blaming Transgo - I'm sure it is something I screwed up in the process of doing the kit.
Any ideas?
Thanks
Any ideas?
Thanks
Take the trans out and go over it carefully.... Might also need a book to help you find it.... Transgo can ge a little hard to understand some times....
One of these first three are good to help you if you need it...
inri
Aug 25, 2019 07:21 AM
anthony oborny
Jan 10, 2010 06:06 PM
