No drive in any 727 trans position after Transgo install
Old Jul 22, 2018 | 11:44 AM
droptail's Avatar
Drove around the block - felt like it went into neutral and quickly popped back into gear couple of times - and overlap in Drive - forgot what gears.
Then when I put it in reverse to back into garage I lost all trans engagement - nothing.
It does show 1pt low - which I doubt would cause the control?
The overlap is band adjustment I assume.
I'm not blaming Transgo - I'm sure it is something I screwed up in the process of doing the kit.
Any ideas?
Thanks
Old Jul 22, 2018 | 11:58 AM
I'd say it's time to go back over the installation mabe pull it apart and make sure you did everything called for. 🙂
Old Jul 23, 2018 | 08:34 PM
Take the trans out and go over it carefully.... Might also need a book to help you find it.... Transgo can ge a little hard to understand some times....
One of these first three are good to help you if you need it...
Amazon Amazon
JPR56
Mar 16, 2020 07:59 PM
inri
Aug 25, 2019 07:21 AM
78cordoba
Apr 22, 2010 03:04 AM
anthony oborny
Jan 10, 2010 06:16 PM
anthony oborny
Jan 10, 2010 06:06 PM
