Panhard bar to 9.25 rear axle
Old May 19, 2012 | 05:44 AM
PK1's Avatar
PK1
I am looking for a BOLT on axle tube bracket ( full circle of coverage ) for the Chrysler 9.25 rear end. Full size Ram, Durango / Dakota RT. Specifically an 03 with rear disc that's being used in project build.
I need to mock up a panhard bar and play with geometry some. I will weld to the bracket to get my clearance dialed in and then weld straight to the tube once its out and jigged to eliminate the "bolt on" bracket all together.
Anybody know where or who makes one? I see plenty for the Fomoc and Bowtie guys but none for the Moper guys??
Thanks!!
Old May 20, 2012 | 03:52 AM
I don't know of any for the 9.25. I guess you could always bolt something to it using the diff cover bolts but I would worry about snapping them off under a load.
If you know about where you want it and have some scrap steel hanging around, build the brackets you want, drill multiple mounting holes for the panhard bar, and then drill two holes in each bracket and use some thin u-bolts to hold it in place. Would this work for you?
Hopefully my crude paint picture helps to show what my thought is.
Old May 20, 2012 | 04:53 AM
PK1's Avatar
PK1
That is an excellent idea!!!! That will work.
I'm only trying to get the throw of the attachment point and I like to mock and double mock all the items to make sure serviceability access of other components isn't impacted negatively.
Originally wanted the bolt on bracket like Ive seen on the circ track car so I could mess with some roll centers but I cant find anything for the mopar guys.
Thanks!!
Jim Kruse
Jun 8, 2012 07:11 AM
johnthegoalie
Jun 2, 2012 10:16 AM
Mango
Nov 1, 2010 03:43 AM
Silverick
Aug 25, 2010 03:08 PM
Jul 24, 2009 09:20 AM
