Transmission, gears or what
Old Aug 27, 2013 | 05:00 PM
Shrug's Avatar
OK I got a 52 Plymouth Cranbrook. It has a 3 on the tree and a flathead 6.
The car is geared seriously low! The effective top speed is like 50 mph.
So my question is this, what is the easiest way to get a little more speed out of the car? Changing rear end gears?
Is there an overdrive for it? Is there any later model trans that I can just bolt to the motor?
I have never attempted a rear end change, is it difficult?
Old Aug 27, 2013 | 05:47 PM
moe7404's Avatar
in those years they had factory O.D. for 3 speed stick trans. they was for better MPG, not speed. they may be hard to find. to in gauge the O.D. you pull a lever. thats all i can remember.
Old Aug 27, 2013 | 07:25 PM
Check and see ? It may have one of the early 8 3/4 rears Other wise you can adapt almost any rear end 8 3/4 would probably be the easiest
Old Aug 27, 2013 | 08:44 PM
Shrug's Avatar
How do I measure that? I have never touched the drivetrain behind the engine. Trans, rear ends, total mystery to me.
Old Aug 27, 2013 | 09:56 PM
I find this difficult to believe, "unless....................."
Have you checked tire diameter against what would have been original?
I'm sure these didn't cruise at 70-80 in their day, but in my local area, growing up, we certainly had 65 mph highways.
Old Aug 27, 2013 | 11:03 PM
Measure the total width of the rear end and measure the distance between the spring perches
Old Aug 28, 2013 | 06:22 AM
Great point....
Old Aug 28, 2013 | 02:43 PM
Someone else could have changed it before you go your hands on it as well. Check out what the other's have mentioned. Maybe pull the diff cover (if not a 8 3/4) and divide the amount of ring gear teeth by the amount of pinion teeth. This will tell you what your axle ratio is.
Old Aug 28, 2013 | 04:10 PM
Ottawaguy's Avatar
Seems really strange to me. I had a 1953 Plymouth Cranbrook, flathead 6, 3 on the tree stock set up and it would easily hit 65 - 70 mph. It didn't have a lot left powerwise at that speed but would certainly cruise right along.
Old Aug 29, 2013 | 09:17 AM
Shrug's Avatar
Yeah it turned out it was a combination of facts. I changed out the front shocks, which were useless, and the carb was seriously lean. Changed the shocks, gave the car a tune-up, took it for a test and got it up to 70.
Aspen77
Jan 12, 2015 08:33 AM
v6spitfire
Feb 18, 2009 10:54 PM
darkcrow
Oct 4, 2008 01:59 PM
debby440
Jun 18, 2008 11:55 PM
transman037
Jan 20, 2008 09:56 AM
