What is correct TorqueFlite transmission fluid for 64 Ply Belvedere 318
Old Oct 12, 2014 | 09:14 AM
Dad-Par's Avatar
Just purchased this vehicle (all orig daily driver) and want to be sure I'm going to use correct fluid. Always remember 'Type A'. Is current replacement Dexron/Mercon (progressive upgrade from Dexron, Dex II, III, addition of Mercon etc) correct for today?
Old Nov 18, 2014 | 04:19 PM
DLJ's Avatar
DLJ
There are quite a few oppinions on what fluid to use, I am using DEXRON II on my 1976 TF, most mopar people like type F and ATF+4 is what Mopar recommends now for all transmissions and steering
https://moparforums.com/forums/f82/t...e-727-a-18008/
Old Aug 7, 2016 | 01:00 PM
cliff32ord's Avatar
Transmission fluid to use in a '70 plymounth small block
I've got a '70 Plymouth Satellite with a small block 318. Nothing in owners manual as to what transmission fluid to use. Can someone please tell me? Thank you in advance.
Old Aug 7, 2016 | 05:18 PM
DLJ spelled it out rite their...
Old Dec 18, 2016 | 12:08 AM
RCEnterprises's Avatar
Any modern trans fluid will work fine in your trans including synthetic. You can also dump in anywhere from 1 quart to a complete fill with straight 30wt motor oil....yes it sounds crazy but works great. I'd stick with 1 quart for a driver since there is no detergent in that old tech motor oil. Your trans will love you forever.
RC
Old Dec 18, 2016 | 08:21 AM
I read an article that you can use hydraulic oil in the older Ford and Mopar trans, thats all type F is with red die.
Dad-Par
Oct 29, 2014 06:31 PM
Dad-Par
Oct 12, 2014 11:27 AM
Dad-Par
Oct 12, 2014 09:18 AM
hlfishman
Dec 19, 2012 07:41 AM
