1953 Dodge Meadowbrook
Old Apr 26, 2023 | 04:39 PM
Crisjr1469's Avatar
So I am seeking any and all help so I had someone start doing my brakes and ended up not doing them so I'm stuck with trying g to put them back myself so I do know somewhat about the cam pins and the anchor bolts with the arrows so if anyone can send me any and all information videos links on how to put them back and adjust them correctly from scratch
please I would greatly appreciate it thank you
OK so when I was going to try everything to put everything back on and do the adjustments like you all said and going by all the links you all shared I noticed the spindle looks VERY VERY worn down like it was rubbing against something any suggestions before I try and put it back together please
Old Apr 26, 2023 | 09:43 PM
dodgem880's Avatar
I found a MTSC (Master Tech Service Conference) brake video from 1950. However, it appears to depict the same duplex drum brakes like on your 53.
Also, is the other side of the car still together? If so, you can use it as a reference.
Chrysler Master Tech - 1950, Volume 3-6 Brake Shoe Adjustment and Alignment
Old Apr 27, 2023 | 05:05 AM
Kuvasz101's Avatar
That is an awesome video!
Old Apr 27, 2023 | 02:52 PM
Lostviking's Avatar
Drop by P15-D24.com. It is a site dedicated to these older Mopars.
Old Apr 28, 2023 | 08:19 AM
Looks Assembled correctly...
Appears you just need to figure out the adjustment?
Old Apr 30, 2023 | 11:25 AM
Crisjr1469's Avatar
Ok so what im trying to ask is this please on the cam pins and spring (the little plate underneath it )is there a certian way they are to be bent to hold the shoes also I think I read somewhere that those plates have to be facing with the lobes facing outward would that be true please like the picture I just added with the circles and arrows pointing
Old Apr 30, 2023 | 12:58 PM
Those are just Shoe Guides... Just put them on dry or use a little dab of disc brake caliper grease on the inner side of the tabs and the backing plate, if you would like..
viperpete
Jul 6, 2021 11:28 AM
Crisjr14
Dec 12, 2020 12:36 AM
crxnug
Nov 25, 2013 06:15 AM
lboggie
Oct 30, 2012 06:55 PM
epflynn
Jul 11, 2008 08:34 AM
