1989 rack and pinion Might be going, Help for advice or suggestions.
Old Apr 30, 2013 | 04:51 PM
floridamtbiker9's Avatar
When I drive my 1989 Dodge Dakota Convertible it makes noises when I turn.
When I go straight I can turn the when about 45 degrees each direction before the truck starts turning.
Please Help for advance.
Thank you in advance.
Old Apr 30, 2013 | 05:29 PM
You need to start by having someone turn the wheel while you watch the steering shaft for looseness to determine weather it is the rack or steering column
Old Apr 30, 2013 | 05:43 PM
mikerp76's Avatar
also check the inner and outer tie rod ends as well.
Old May 5, 2013 | 06:04 AM
Well driving home from work. Lost my sterring. The 2 bolt that bolt the rack and pinion to the cross support frame under the engine ripped right out. Now I have to find a professional welder to repair. Then I will get a new rack and pinion.
Old May 5, 2013 | 08:00 AM
There was a recall on those years for the rack and pinion doing just that.
roger.bell
Jul 2, 2015 10:20 AM
RetroRack Global
Mar 24, 2014 07:39 PM
cattmann
Aug 30, 2013 12:59 PM
Leem
Oct 29, 2011 07:13 PM
6fury4
Dec 28, 2009 08:30 PM
