68 Imperial Power Steering Hose
Hi folks. Not sure if I am posting this on the right category.
I am trying to replace my high pressure P/S hose. The new hose I got on the steering box side has a 1/4 flare female fitting. But the fitting on the steering box is 5/16s. I tried to find a transition fitting, but that did not work. Hardware stores did not have it, and even Jegs did not have it. I took the fitting off the steering box hoping to replace it with a 1/4 flare male. I was hoping that the other side would be some simple NPT. But it was not. The diameter of the threads are just under 1/2 inch, and the threads look like standard fine pitch bolt, may be 1/2-28. And there was a copper washer to seal it.
Any ideas what type of fitting that is, and where can I get a fitting with 1/4 flare?
Thanks
Thanks
I found these folks.
http://www.classicindustries.com/pro...s/1253572.html
I doubt this is what I need though, I need the 1/4". At any rate, I am a bit confused with this website, and I will call them tomorrow. But may be you guys have more ideas.
Mopar101
Sep 30, 2015 08:59 AM
cvon
Apr 12, 2010 09:49 AM
