69 Roadrunner front shocks replacement
Old Aug 12, 2013 | 03:38 AM
dgp_naples's Avatar
yesterday I started to remove my front shocks just following my service manual and unbolt top first then the bottom.
Trouble is I can't pull out the lower bolt because the tie rod is in the way.
Do I have to remove the torsion bar and tie rod assembly to get that bolt out?
Old Aug 12, 2013 | 09:38 AM
This makes no sense at all. The tie rod is inches away from the shock bolt. Can't you turn the front wheels left/ right to clear what you need? You have a shop manual?
Old Aug 12, 2013 | 10:06 AM
Sounds like you are trying to remove the lower control arm to get the shock out ? Not the way to do it..
With it up on jacks and weight off of the control arm you can get the shock out. What you need to do is remove the upper and lower bolts and compress the shock. Use a large screwdriver & pry the shock up & out of the lower mount
Old Aug 14, 2013 | 06:09 PM
dgp_naples's Avatar
picture shows the bolt and tie rod position
I have no idea how to post a photo. I have uploaded per the instructions and it shows as a jpeg but it does not attach to my reply. So I copy and paste the uploaded link below.
The tie rod is directly in the way of removing the lower shock bolt, irregardless if I turn the steering wheel or try to lift up the wheel hub.
Old Aug 14, 2013 | 06:23 PM
You have a sway bar ! Just undo the long bolt, or get a long pry bar and pry the sway bar up enough to get the bolt out
inri
Jun 10, 2013 03:54 PM
oldiebutgoodie
Oct 4, 2012 06:56 AM
bjm6469
Jan 18, 2012 02:17 PM
GreghasaDart
Mar 25, 2009 02:06 AM
userofme
Apr 7, 2008 12:34 PM
