73 challenger Power to Manual brakes
Old Mar 16, 2012 | 09:50 AM
Jwhis's Avatar
Hey new to the forum! Question about the Power to Manual brakes for the 73 dodge challenger. This car was originally power brakes. this is a 4 bolt master cylinder. the car has front disc rear drum brake. To attach the master cylinder to the firewall do they make an adapter plate for it to line up? Hoping someone has done this before and can give me some insight. Thanks!
JWhis
Old Mar 16, 2012 | 05:25 PM
You can use the same master cyl. You need the re reinforcement plate that goes on the firewall and the correct brake pedal to master rod
Old Mar 16, 2012 | 10:16 PM
Jwhis's Avatar
Do you happen to know of any place i can get this plate? It's the only thing i am having issues with finding.
Old Mar 17, 2012 | 02:54 AM
rdrunner1974's Avatar
Master cyl.
http://www.performanceonline.com/Mas...ing-Valves-01/
Old Mar 17, 2012 | 06:43 AM
Jwhis's Avatar
Using that adapter plate makes me go to a 2 bolt master cylinder. Is there such a thing where i can use the 4 bolt MC?
Old Mar 17, 2012 | 12:36 PM
You need to use the newer style master with that adapter . Any A,B,E and many others will have the plate so there are a lot of options
Old Mar 19, 2012 | 04:07 PM
Jwhis's Avatar
Thanks for the link. basically i have 3 options
*switch to a 2 bolt pattern MC
*have a custom adapter plate made
*user the 4 bolt pattern MC and drill the holes in the firewall (which is what i am doing)
with either of these 3 you still need the pushrod which you can order from performanceonline.com for $16.99
Old Mar 19, 2012 | 04:09 PM
Jwhis's Avatar
*use the 4 bolt pattern MC and drill the holes in the firewall (which is what i am doing)
1968GTX
Jan 25, 2014 10:40 AM
dodgeman68
Jan 12, 2013 05:15 PM
HonkyCat
Nov 3, 2012 10:09 AM
thedusterridesagain
Sep 20, 2012 07:57 PM
Rbaisch
Dec 1, 2008 02:17 AM
