74 Dart Lifting front end/ replacings springs
Old Jun 13, 2013 | 09:28 AM
ThomasNieman710's Avatar
Can someone help me to get more space in the front end. I have some specific tires I'm trying to fit but I barely rub. I need just an inch or so more on the height of the body.
Does anyone know what size springs are on a 74 dart swinger?
Old Jun 13, 2013 | 02:01 PM
It's a torsion bar suspension. You can raise the front some by cranking the preload up. The large bolt under the lower control arm. Make sure to raise the car up so there is no load Turn them equally a little bit at a time. Then have the front re aligned
Old Jun 14, 2013 | 09:43 PM
Kern Dog's Avatar
I have read before the suggestion to realign the front end after adjusting the ride height. Maybe I have just been lucky, but I have never felt the need. I never felt a difference in the alignment after raising or lowering the front by an inch. My cars didn't toe in or out more to any point I could tell. The camber change would have been tiny if anything.
I'm not advising against it. I'm just saying that with only an inch of height change, the alignment should still be pretty close to what it was.
Old Jun 15, 2013 | 06:56 AM
Your tires will tilt inwards after you crank up the torsion bars.
Old Jun 15, 2013 | 09:45 AM
Within limits, you both may be right. Cranking the T bars up/ down DOES affect alignment, but these cars originally called for alignment settings which cambered the tires out at the top for bias tires. Modern radials call for the OPPOSITE, IE the tops of the tires cambered IN.
Here is a widely accepted standard for aligning these cars for use with modern radials instead of bias tires:
http://www.allpar.com/history/mopar/...alignment.html
Scroll down to the "skosh chart" which calls for NEGATIVE camber IE tops of the tires cambered inwards.
Old Jun 15, 2013 | 08:23 PM
Kern Dog's Avatar
What does this mean?
More Camber?
Less Camber?
I never noticed in my cars. Must have been the clean living!
Old Jun 17, 2013 | 11:25 AM
This is all great stuff! I did have a rough patch over the weekend. Got the front end up 3/4 of an inch and the turn radius now clears. But this also accentuated a very bent A-arm/bar. thing. (you guys know of what i speak)
So I had it hoisted at a shop and a gentleman said he could reweld it, but it won't be cheap at $70/h for labor+parts. I've consider installing new parts?
opinions?
Old Jun 17, 2013 | 05:16 PM
More Camber?
Less Camber?
Camber goes two ways. tires "in" at the top, tires "out" at the top. Originally, older bias ply tire alignment settings were "out" at the top --look at most any old car or truck with a "straight" front axle. Usually you can see that
Modern radials like the tires "in at the top" as sugessted by the All Par Site
If you actually read this page, and look at the "skosh" chart, it will become clear:
So absolute "plumb" is zero camber
"More in at the top" is "more negative camber"
"More out at the top" is "more positive camber"
JETBLU
Jul 20, 2015 10:40 PM
ThomasNieman710
31
Jul 11, 2013 05:00 AM
dart swinger
Nov 29, 2010 12:49 PM
bruger
Jul 16, 2010 10:14 AM
theironman
Feb 6, 2010 10:08 PM
