Adjust Steering
Old May 23, 2019 | 05:11 AM
Rute66's Avatar
Adjust Steering
Hi
I have a 1970 challenger with 340/727 and power steering.
I have problems adjust my steering. All is okay with steeringball. All measurement Camber, caster and toe in green.
If I drive forward wheels are becomming minus in toe ( not only a little, but a lot) and the tires are worn.
If I drive backwards the wheels becomes straigt again.
Do any one know what I'am doing wrong?
Regards
Forward
Backward
Tony
Old May 23, 2019 | 07:29 AM
I'd say your toe has got to be off, is it possible the incorrect specs were used?
Old Jun 10, 2020 | 02:35 AM
Rute66's Avatar
Toe 1970 challnger
Hi
is there a special procedure for adjusting toe on an E-body?
when we adjust we use +0,10 toe in. (-0.5 camper, +3.0 caster)
when taking down from lift first time, and make a test run, it Will chance the toe to more in, if I go backwards it staighten up the wheels again.
2. time we put on the lift and connect the adjusting Unit, the toe is know wrong, we adjust again, and this time it Will be better.
Do anyone have the same problem?
Tony
Old Jun 10, 2020 | 04:03 AM
Something is loose, tie rods, Center link ends, control arm bushings or ball joint.
Little Joe
Oct 29, 2010 05:30 PM
Jasonmiester
May 18, 2010 06:09 AM
allenw
May 16, 2009 02:33 AM
44072Charger
May 2, 2008 10:01 AM
ucfierocharger
Nov 8, 2007 01:54 PM
