Bad Viberation/shutter in car
Old Aug 23, 2011 | 03:18 PM
gearheadmike's Avatar
ok ive noticed in my car science i bought it that it has a bad viberation in it 35mph under hardly anything anything over say 50mph when i hit the breaks to slow it starts to shake/shutter i pulled my front wheels off 2days ago and pads look good and the rotors are around 1/2 year old. the tires are 1/2 a year old and still look new. Ive been told universals/bearings/tir rod ends/ect idk im going to try universals and see about that but idont think it is.
Any sugjestions?
Old Aug 23, 2011 | 04:26 PM
If it only happens when using the brakes Most likely you have a warped rotor
Old Aug 23, 2011 | 04:54 PM
sometimes with brakes sometimes not i know it cant be rotors there practicly new guy put them on abt year ago car sat its still new metal were the hub part is.
Old Aug 24, 2011 | 04:10 AM
Archer's Avatar
Mike -
Make sure your drive shaft is straight, balanced and the U joints are centered correctly.
OK, could be a lot of things but drive shaft issues can do that.
Old Aug 24, 2011 | 06:33 AM
the cars been taken care of but 2day in going to put new universals in it and clean any rust off the drive shaft if there is any and look at it for anything "not right" lol
Old Aug 24, 2011 | 04:32 PM
well i think i narrowed it down to universals or front rotors. stuff went on wit fam took it out on car did some burn outs and hit the breakes a little hard. now at 45mph it shakes alot! and just as bad when stoping from that or higher speed and i noticed it shakes the car through out u can see the seats/door panels/windows shake so i think its universals. idk
Old Aug 25, 2011 | 12:10 AM
MercuryDon's Avatar
Check the tie rod ends, pitman and Idler arms. Then the Ball Joints and control arm bushings .
Old Aug 25, 2011 | 03:09 PM
ok jacked the rear of car up i tried moving the drive shaft sided 2 side near rearend no play... now at the trans tail i tried it and theres movement and i can see were the tail shaft seal been leaking over time/still and that the rubber trans mont i can pull apart with my fingers do to trans fluid eating at it and its moves a lot to me. Another thing is i grabed the rear tire turned it and it turned good then feels like its catching like a warped rear drum. so Im thinking im going to: put new universals in/new tail shaft seal/trans mount(rubber )/rear drums and pads& spring kit.
Old Aug 26, 2011 | 08:42 AM
JS23's Avatar
Ditto Merc Don
also check the bushing at the front of the strut bars.
Try this on your front rotors. clean with brake clean.
Sand the rotors with 120 grit. brake clean again.
Look up brake bed in procedure. Or just replace the pads.
Old Aug 26, 2011 | 09:56 PM
was bored tonight so i said f#$k it and i put the 2 new universals in.... it paid off no more viberation still going to redo rear breaks and the tail shaft seal&mount/bushing. Then to figure out y its pulling to the left.
stickshifted
24
Dec 31, 2008 04:01 AM
cide
Sep 8, 2008 08:47 AM
Joel@lavinconstruction.co
Apr 27, 2008 03:58 PM
1cerberus4u
Apr 18, 2008 06:55 PM
62sportsweep
Apr 7, 2008 03:38 PM
