Brake Booster
Places like classic industries, jegs, summit, theramman.com, year one...
The ram man (Wayne) was really helpful to me just yesterday! He sells a complete unit..but will answer any question you may have..
If you haven't already, Do a google search with your year and make and power brakes..that should give you all kinds..
Good luck..
Good luck..
I would sugest a complete disk brake kit !!!!! www.masterpowerbrakes.com If you are planning a cam ? Keep the manual brakes !!!!
I used SSBC front caliper kit on my "65. Totally painless as I did not have to change
spindles or all that other crap you forage for in junk yards. Kitt under $1000 and it
came with everything - master, flex lines etc. It's based on Corvette brakes with
Girling 4 cylinder calipers. Serious braking for a kitt. I did not change the rears to
disk because it's a blatant waste of good
that could be used wisely elsewhere.
Rears only do 20% of braking and that's mainly to stop nosedive and coming loose.
I did however install Hydroboost on my '65. It is truely easy to install and the best
braking system bar none. Had it with vacuum boosters because I had only 16 inches
of vacuum and that doesn't quite cut it.
that could be used wisely elsewhere.Rears only do 20% of braking and that's mainly to stop nosedive and coming loose.
Oh, by the way, I do have the correct booster you need and it is like new. I
believe it's a Bendix unit that mounts directly to the firewall. Took it out of
a '67 Fury and had it reconditioned. You can see it at:
https://www.jimsautoparts.com/brake.htm
If interested shoot me an offer at: rootyf@gmail.com
