Brake drum???
Old Jul 15, 2012 | 07:01 AM
a.johansson84's Avatar
Brake drum???
Hi, is the brake drum fixed in the hub nut? or should it just be to use a puller and pull him? I removed the hub nut and used a puller between the tire bolts, but my extractor broke (cheap crap). It's on my Dodge Pioneer from 1961..
Old Jul 15, 2012 | 08:42 AM
It's not clear to me whether you are trying to get the hub/ drum assy off the axle or trying to now get the drum and hub separated
You need a massive puller for this, and good ones are not cheap. You COULD make one with heavy enough material. The good ones used to be made by people like OTC
http://shop.advanceautoparts.com/wcs...4_pri_larg.jpg
Those will pull just about any tapered axle hub on the planet, Jeeps, Internationals, Dodges. They make not work on early Fords or VW's with the "big" bolt pattern around the edge of the drum. They are big, expensive, massive, strong. The nut and "wrench" is built this way so you can tighten it up, and tap against the nut and the wrench with a hammer, to "shock" the hub loose.
Whatever you do, don't use a puller that hooks around the outside of the drum, nor pry around the outside. Sometimes putting pressure on the puller, then heating the center of the hub helps.
To separate the hub and drum..................
Generally, the wheels studs have a "riveted" area where they come out the front of the drum and transition to the stud itself. This is generally called a "swedge" or a "swadge." You cannot just drive the studs out, you'll ruin the holes in the hub. You need a "stud cutter" or a "swadge cutter"
Here's some examples
http://www.goodson.com/Brake-Drum-Swedge-Cutting-Tool/
Old Jul 16, 2012 | 06:08 AM
I try to remove the drum so I can check the brake pads look and brake cylinders. The decreased unevenly behind, so it did not go through the Swedish vehicle inspection.
Old Jul 16, 2012 | 06:12 AM
I'm thinking about this kind of puller. It says "fits most drum brakes."
Old Jul 16, 2012 | 06:47 PM
I cannot tell how that thing works, can you post a link where you found it?
Old Jul 17, 2012 | 06:27 AM
I found it on a swedish site
http://biltema.se/sv/Bil---MC/Verkty...ragare-191139/
Old Jul 17, 2012 | 09:00 AM
Sorry, I just don't know. It appears to be threaded, but the cylinder in the center must be large enough to go over the top of the center of the hub.
Old Jul 17, 2012 | 01:48 PM
What you need for the rears on the older Mopars Is a slide hammer. Has 3 fingers that bolt to the axel studs with a 18"-24" bar with a big weight to slide on it
Old Jul 17, 2012 | 04:38 PM
I disagree. What he has is the old tapered axle with the huge nut on the end. You need a tool (or make one!!) like the OTC one I referenced.
Old Jul 20, 2012 | 01:31 PM
I can take a pic of the brake drum if that is easier..
Old Jul 22, 2012 | 05:00 PM
Timmoparman's Avatar
If you just want to pull the drum for brake job, Then I just took off the nut and bearing and take the drum off that way.
Old Jul 25, 2012 | 09:15 AM
so easy was mine forward. But back it's not losing by simply removing the nut. I was try that already...
Old Aug 9, 2012 | 08:50 AM
MrOldart2U's Avatar
I havent worked on the taper axle/drum assy in a long time but i have had luck heating the drum close to the axle and giving it a decent 'bump' with a hammer.
Old Aug 11, 2012 | 04:46 AM
I took such a puller that I showed the picture and drilled new holes, as it did not fit in the gaps that existed. Then I put it on the wheel studs and bolted into the middle screw. When it was tense, so I hit with a hammer and the drum came off nicely..
Old Aug 11, 2012 | 10:05 AM
Ah, very good. I'm happy you got it off. Here in the states, there are a few older "rigs" which used those, old Fords, Studebakers, and of course Mopars. Jeeps, International Scouts and pickups. Some of those were a bastard to remove after years of rust
Old Aug 12, 2012 | 07:08 AM
So, now I sat there glued new brake shoes and lubricate the brake cylinder on the right side. Now it should go through the Swedish vehicle inspection.
I'm going in on Wednesday at 15:50 Swedish time .. just keep your fingers crossed
motorcitymopar586
Sep 28, 2013 12:12 PM
Mike66Newport
May 13, 2011 06:24 AM
Bossta
Oct 6, 2009 09:56 AM
jar84203
Aug 18, 2009 08:21 AM
afastcar
Dec 18, 2008 04:15 PM
