convert 1966 charger to disc brakes
I have a 1966 charger that I want to convert to disc front brakes. I have a set of front disc brakes and all the hardware off of a 1967 dodge coronet. The only way the spidles will mount is with the caliphers on the front of the spindle---------What am I missing??? Is there any info on line with procedures and maybe pics?
Please help if you can!!! Thanks
I'm not versed in the specifics of B body stuff but on the A bodies you just swap the spindles on whichever side, and you can mount the brakes front or rear, depending on which sides the spindles are.
I put mine on the rear, to be sure they don't interfere with the anti sway bar, but that's not where the factory put them
EDIT just took a look at the service manual, and I'd say you simply have the spindles on the wrong sides
