convert 1966 charger to disc brakes
Old Mar 15, 2014 | 05:47 PM
bigearl777's Avatar
Question convert 1966 charger to disc brakes
I have a 1966 charger that I want to convert to disc front brakes. I have a set of front disc brakes and all the hardware off of a 1967 dodge coronet. The only way the spidles will mount is with the caliphers on the front of the spindle---------What am I missing??? Is there any info on line with procedures and maybe pics?
Please help if you can!!! Thanks
Old Mar 15, 2014 | 06:44 PM
I'm not versed in the specifics of B body stuff but on the A bodies you just swap the spindles on whichever side, and you can mount the brakes front or rear, depending on which sides the spindles are.
I put mine on the rear, to be sure they don't interfere with the anti sway bar, but that's not where the factory put them
EDIT just took a look at the service manual, and I'd say you simply have the spindles on the wrong sides
Old Mar 15, 2014 | 07:33 PM
bigblock's Avatar
Consider brake line/hose routing.
Old Mar 16, 2014 | 10:58 AM
bigearl777's Avatar
If I install them with the caliphers toward the front they will bolt up but when installed properly the bolt holes will not match up.
Old Mar 16, 2014 | 04:49 PM
What bolt holes? You have the correct ball joints? Again not familiar with B swaps (even though I've owned some,) but on the A's the ball joints are different for disc / drum
kevinrunner71
Feb 16, 2014 07:23 PM
Rbaisch
Dec 1, 2008 02:17 AM
1969GTX
Aug 7, 2008 09:51 PM
dotman
Nov 9, 2007 07:59 PM
kunfumark
Mar 7, 2007 09:25 AM
