Disc brake rotors dont fit, 1970 challenger
Old Mar 23, 2020 | 06:59 AM
Richieg's Avatar
Hi. I'm rebuilding a 1970 challenger. I've ordered some new disc rotors. My spindle and bearings are too big on the car, the rotor won't fit. Did the spindles come in different sizes? The application checker on the website I bought them from said they would work and they dont.
Old Mar 23, 2020 | 02:09 PM
Are you sure it didnt give you choice of 10" or 11" Rotors?
Old Mar 23, 2020 | 03:18 PM
Richieg's Avatar
yes, they are 11 inch, just like the ones I removed from the car
Old Mar 24, 2020 | 11:37 AM
Check the old Bearings and see if that number will fit the new rotor hubs? Check the seals also?
Old Mar 24, 2020 | 03:44 PM
Richieg's Avatar
Hi. Thanks for the reply. The 1970 rotor, seal and bearings are all too small to fit on my spindle. I think it might be a possibility that a different spindle was put on this car as a disc brake upgrade or something. I have ordered a seal from a 1973 challenger, to see if it fits my spindle. I think the 1973 spindles might be larger. Hopefully then, ,I can order the rotors and bearings to fit too, from a 73. I guess the other parts will be going on ebay. Thanks. Time will tell.
Old Mar 26, 2020 | 09:08 AM
That was where i was going to go next !!!! Might have been converted!!! Keep us posted. Hope that is the case.
Old Mar 26, 2020 | 04:19 PM
Richieg's Avatar
Yes, I have the seals ordered and should be here in a couple of days. Thanks for the help, I'll definitely let you know. Thanks again
Old Mar 28, 2020 | 03:57 PM
Richieg's Avatar
Well, the seals I ordered for a 1973 challenger definitely are the correct ones. They fit my spindles, so rotors and bearings are now ordered. Looks like were making progress, it was definitely converted to discs. Thanks for the help! Now all I have to do is figure out what kind of discs they put on the rear with a Dana 60. Buying a used racecar with no information available is not easy sometimes.
Old Mar 29, 2020 | 08:34 AM
Good on the fix for the front.... Now you just need to start a book with all the info and parts numbers so you dont forget for next time.
On the rears, If you can take a couple of pictures and post them up here. We will do our best to help away.
Old Mar 29, 2020 | 02:41 PM
Richieg's Avatar
thanks, I will do that. I appreciate the help bunches!!
crxnug
Jul 8, 2016 03:13 PM
vanishing point
Mar 13, 2009 02:22 AM
moparmadman
May 25, 2008 10:53 AM
dotman
Nov 9, 2007 07:59 PM
