front brake hub seal
Old May 1, 2017 | 05:07 PM
t65fury3's Avatar
hello i have a 1965 plymouth fury lll 318 motor I'm looking for the front outer wheel bearing seal .maybe a part number might help locals show nothing
Old May 1, 2017 | 07:30 PM
There is an inner seal but NO outer seal SO inner seal,bearing, rotor/drum, bearing, castle nut and dust cap
Old May 1, 2017 | 10:38 PM
t65fury3's Avatar
thanks for the reply saw the book and just double checking the dust cover is the cap .what a time finding a hub someone before thought beating on the hub where the inner bearing goes was a good idea totally screwed it up.found a used one but what happened if i needed a new one .could not find one might you know where just in case the passenger side is bad but i think i did work on that one just wanting to be sure ill check later lots of stuff going on.again thanks so much.
Old May 14, 2017 | 02:48 PM
t65fury3's Avatar
one side down one to go then is registration time
dodgem880
Feb 4, 2024 01:14 PM
demetri
Feb 26, 2014 07:32 PM
Shrug
Mar 26, 2013 04:41 PM
DodgeRamFan23
Apr 9, 2011 07:33 PM
Dave E
Oct 7, 2010 05:18 AM
