Help with Rebuilding front end-67 Charger
Old Jan 25, 2021 | 02:23 AM
dgp_naples's Avatar
This is my first time to rebuild a Mopar front end suspension. I have the engine out of my car and have removed the torsion bars. I also removed the nuts and washer from the upper control arm (at the tower) but left the bolts in place. I also have removed the top nut on the shock. With the car on jack stands and the front suspension hanging, what is the best way to relieve the tension on the upper control arm bolts so I can remove them from the tower?
It seems that the weight of the suspension hanging would just create more tension on the bolts holding the upper control arm on the tower. Once I can remove the upper control arm bolts , I thought I would drop the k-member with the suspension so I can re-build off the car and restore the k-member finish.
Any advise is appreciated.
Old Jan 25, 2021 | 11:27 AM
Take the spendles loose from the upper control arm and drop the lower asm if you can... Remove the upper control arms their after.... Just my 2 cents...
"Sorry I didnt reply to your PM"... My time has just been to limited latey to spend a lot of time on the Sites.... Lot of good people on here to help you out... Just take a little waiting time at times... Keep us posted... cheers
Old Jan 25, 2021 | 03:14 PM
dgp_naples's Avatar
Thanks Racerhog.
Timbo
Oct 10, 2017 07:44 PM
sgp7679
Jul 8, 2011 06:50 PM
rc-ltu
Mar 16, 2011 06:35 PM
mytracy
Dec 22, 2010 06:24 AM
mytracy
Nov 25, 2010 10:51 AM
