Low master cyl bleeding issue
Old Sep 28, 2016 | 01:23 PM
ermracing's Avatar
Are there any special tricks for bleeding a 4 wheel drum setup with a frame mounted master cylinder? 4 of the wheel cylinders are higher than the m/c and we're having problems getting them bled. When using a vacuum bleeder the flow doesn't continue once the vacuum is turned off, even when the drain line is lower than the m/c.
Dave
Old Sep 28, 2016 | 08:24 PM
Dave... Use a Pressure Bleeder.... That should get it handled for you....
Something like this one, with the rite lid...
http://www.nationaltoolwarehouse.com...13332C469.aspx
cudaracer
Jan 7, 2020 12:50 PM
scotts74birds
Sep 14, 2010 09:46 PM
buddyleewv
Aug 17, 2010 08:23 PM
ariesfs
Dec 31, 2008 03:14 PM
Mixmastermerrill
Oct 20, 2008 09:22 PM
