Polyurethane bushings?
Old Aug 23, 2012 | 05:39 AM
Gorts 5th's Avatar
Smile Polyurethane bushings?
im looking to replace my suspension bushings has anyone ever used poly kits
what are your suggestions
86 5th ave
Old Sep 29, 2012 | 09:34 AM
Chryco Psycho's Avatar
yes they are great just use lots of the grease so they do not squeak , I generally use Energy parts
Old Oct 14, 2012 | 07:39 AM
Gorts 5th's Avatar
Cool
just got my upper control arm bushings replaced
and i set the alignment
rebuilt the bushings on the 1 1/8 sway bar
lowered the rear end and she pulls down the front end when i throttle her through the corners i dont see any visible sign of side wall scuff
when i first test drove her i almost turned it into the ditch i did not expect that kind of "push" from the front end
boy what a difference i still have the 5th ave ride with that cornering improvement
after the drive line swap i plan on installing the rear bar also thinking of a panard bar i can see a little side to side movement in the leaf springs
Attached Thumbnails Polyurethane bushings?-p1020259.jpg   Polyurethane bushings?-p1020258.jpg
sixfive407
Aug 30, 2010 09:17 AM
nater
Jun 2, 2010 02:48 AM
craveman
Jun 2, 2009 02:45 PM
AirBorne
Apr 19, 2008 04:02 AM
moparsforlife
Dec 20, 2006 11:49 PM
