Power steering loses boost at low rpm - '70 AAR 'Cuda
Old Jul 29, 2012 | 11:26 AM
AARinOntario's Avatar
Any thoughts about this? I worked for Chrysler in the late '60s and had a '69 Dart GTS company car that behaved exactly the same. Power steering would lose its boost at very low rp. (like foot off throttle turn into a driveway)
Old Jul 29, 2012 | 08:50 PM
What is the idle set too ?
Old Jul 31, 2012 | 08:22 AM
Offhand I don't know, but it's not too low. I'll check it on the tach and post another message. But actually I have another problem where sometimes the gast idle resets, so I have to give the throyyle a kick to slow it down. When it's idling correctly, it feels and sound right, doesn't stumble or hesitate...
Old Jul 31, 2012 | 04:27 PM
Sounds like a throttle blade is sticking, maybe worn throttle shaft in the carb, or you need a better return spring, or throttle cable bad/too tight adjustment
Old Aug 9, 2012 | 08:14 AM
AAR power steering issue
The car is idling, in drive, at about 1100 rpm according to the tach in the dash. (That is when the engine speed drops down correctly upon deceleration. When the fast idle resets, it idles a lot faster.) So I don't think a low idle is the cause of the power steering issue.
Old Aug 9, 2012 | 08:45 AM
MrOldart2U's Avatar
Have any of the pulleys been changed? larger for some accessories smaller for others? Maybe a smaller p/s pump pulley would help?
vobile
Mar 13, 2014 05:47 PM
Johnny2stroke
Dec 27, 2011 04:42 PM
rabys
Sep 14, 2008 04:05 PM
rabys
Mar 22, 2008 11:37 AM
rabys
Nov 25, 2006 08:46 PM
