Residual pressure elimination
Old Jul 20, 2022 | 10:04 AM
DriverOfMissDD's Avatar
Customer car 1970 Demon street/strip.
Just installed a new manual disc brake conversion brake kit from The Right Stuff.
Front brakes and master cylinder.
Installation was smooth.
*** Only propo valve in system is a manual for the rear brakes ***
Retained rear drums
Bled system several times via gravity, back bleed, then pressure bleed.
The front calipers retain pressure, thus dragging the rotors. I crack the bleeder, a little spurt, then the rotor turns freely.
Pump the brakes a couple of times and they lock up until I open the bleeder to get that little spurt.
Calipers are plumbed direct from M/C into a T then to each wheel.
Rear drums do not lock up.
Any ideas ?
The Right Stuff is now owned by Restoration Parts Unlimited and they offer zero tech assistance on their website.
Old Jul 20, 2022 | 12:21 PM
Archer's Avatar
D -
Off the top of my head: is there a proportioning valve, and was it set up correctly?
Old Jul 20, 2022 | 01:53 PM
Old Jul 20, 2022 | 04:51 PM
fivepoint's Avatar
Is the piston in the master cylinder releasing all the way? Just wondering if the rod on the brake pedal needs to be shortened a little.
Old Jul 21, 2022 | 08:53 AM
I Agree with five points..... Also double check the flex hoses to make sure they are not working as a one way check valve... If that's all good I would say you have to remove or change to a lower residual valve setting.
gbm97
Jul 21, 2017 05:50 PM
Raymond Nichols
Mar 31, 2016 10:12 AM
Js TreeServ
Mar 17, 2016 09:43 AM
Turkr42
May 14, 2015 03:21 AM
rbrother
Jan 19, 2010 01:38 PM
