SUSPENSION UPGRADE HELP-WANNA GO LOW
Old Jan 14, 2013 | 08:32 AM
70Coronet's Avatar
Talking SUSPENSION UPGRADE HELP-WANNA GO LOW
I want to lower my coronet, going for more of the pro-touring style, I have been all over this site and google and have seen lots of different ways from lowering by loosening torsion bars(did a little on mine didnt see much result except handling started to go down) to flipping the rear spring mounts ect.. Basically looking for anyone here who may have done it or has some good advise. thanks
Old Jan 14, 2013 | 08:36 AM
70Coronet's Avatar
picture of how it sits now, I would like the front and rear tires to tuck enough to cover the rubber on the top side of the rims
Attached Thumbnails SUSPENSION UPGRADE HELP-WANNA GO LOW-user12882_pic4996_1337984663.jpg
Old Jan 15, 2013 | 06:33 PM
mikerp76's Avatar
it depends on how much you want to spend you may want to start here. for some ideas. http://www.hotchkis.net/search.html?...mitForm=Search
Old Jan 15, 2013 | 06:40 PM
It may be hard to turn with it that low without the tire hitting. Look for some drop spindles
Old Jan 15, 2013 | 07:19 PM
mikerp76's Avatar
fisrt thing i would do before you drop it that low would be to measure how much of a drop that is then measure from the lowest point of the car to the ground that amount.
Old Jan 16, 2013 | 07:11 AM
70Coronet's Avatar
Thanks for the info, I'm a little worried about the passenger side header hitting it sits pretty low but definetly want to get the front down about 2 inches-probably end up doing drop spindles in front and trying either the lowering leafs in back or drop spindles in front
Old Jan 16, 2013 | 07:30 AM
70Coronet's Avatar
This is the look I'm going for but maybe with a little more tire and a little less rim
Attached Thumbnails SUSPENSION UPGRADE HELP-WANNA GO LOW-0809phr_09_z-1970_dodge_super_bee-front_right_view.jpg
Old Jan 16, 2013 | 01:17 PM
You are aware those are probably 20" wheels. Makes a big difference
Old Jan 16, 2013 | 04:46 PM
70Coronet's Avatar
I have 18" wheels on my car with a 295/45 tire-refer to pictures) and thats why I said a little more tire and a little less rim I easily have more rubber by 2" than he does, thanks for the comment
Attached Thumbnails SUSPENSION UPGRADE HELP-WANNA GO LOW-zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz.jpg   SUSPENSION UPGRADE HELP-WANNA GO LOW-copy-2-3241nnh_27.jpg
Old Jan 16, 2013 | 05:08 PM
Air bag it.
Old Jan 16, 2013 | 06:37 PM
mikerp76's Avatar
it looks like his lowest point of the car is just about even with the bottom of the rim. one good bum and he's hitting the ground.
Old Jan 27, 2013 | 11:37 AM
Chryco Psycho's Avatar
PST has drop spindles for the front although you should be able to get a couple of inches lower easily by loosening the adjuster bolts , make sure you lubricate them & take the weight off when you adjust them . What size T bars do you have ?
You can add lowering blocks between the spring & diff in the rear , make sure you use new U bolts .
29
Apr 28, 2015 06:17 PM
bodydisposal
May 14, 2011 02:25 PM
Mango
Sep 13, 2010 06:52 PM
CantRamItDodgeIt91
Aug 5, 2009 10:12 AM
richiesdodge383
May 13, 2009 04:24 PM
