swap to new master cylinder?
Old Dec 20, 2013 | 05:33 AM
Dave E's Avatar
Any benefit to swapping from the old cast iron reservoir master cylinder to a newer style plastic? I happen to have one from a 98 2500 truck I parted out that is in excellent shape. Assuming it will bolt to my 86 W250 booster will it be any advantage over the old?
Old Dec 20, 2013 | 05:45 AM
NO benefit. Cast MC is probably 4 bolt too...
Old Dec 20, 2013 | 05:59 AM
Dave E's Avatar
Actually the old cast one is two bolt and the pattern looks almost identical... I have a rudimentary understanding of hydraulics and I know that if the bore and stroke of the piston is different you could drastically affect the force generated at the wheel cylinders (for better or worse). I may just hold on to the one I pulled from the 98 and in the event my cast iron takes a crap I will swap it in and see.
Old Dec 20, 2013 | 02:00 PM
moe7404's Avatar
i have been told that the aluminum cyls cant be rebuilt. but dont know for sure. the hydraulics works like this . i had a heavy duty d250 1982. it had 1 ton brakes. i changed the rear cyls from 1" to 7/8 and the rear stopped locking up. I.E. less power. if you change the front master cyl to a smaller size you will put less power to the wheel cyl, reducing over all lock up.
MojoHaiku
Aug 22, 2012 10:34 AM
mytracy
Dec 7, 2010 08:11 AM
jar84203
Oct 12, 2010 05:07 PM
Imperial1973
Sep 5, 2009 10:17 AM
buttslapper
Oct 1, 2007 06:32 AM
