updated steering components for 64 Barracuda
Old Oct 29, 2012 | 03:16 PM
mar-tay's Avatar
By now I've pretty much covered most of the components in the front end of my 64 a-body with the exception of the steering linkage (tie rods, pitman arm and idler arm). I've been told to update to the bigger style tie rods, just not sure which ones will work, seems nobody list them for a 64. As well the idler/pitman arms are pretty wispy, is there an update for them? Is it really needed? The LCA are boxed the k-member is gusseted new tubular upper arms with a disc brake set up and bigger ball joints too, just need the parts mentioned above. Thanks!
Old Oct 30, 2012 | 06:38 AM
Chryco Psycho's Avatar
The B & E body can use the larger C body tie rod ends , the conical pin is the same size but the thread into the sleeve is 1/8 larger , I am not sure if the C body parts will work in the A body though , contact PST , they may have an upgrade for you
Old Oct 30, 2012 | 07:45 AM
One up date is to the later style idler arm.. Also requires the instal of later K member
Old Oct 30, 2012 | 03:50 PM
mar-tay's Avatar
Thanks for the input! all ready set on the k-member. I think it was the c-body tie rods I had mentioned, but with out stronger pitman/idler arms doesn't seem worth it. I'll go with the stock stuff for now I guess.
Jasonmiester
May 18, 2010 06:09 AM
red2bunkeru
Mar 17, 2010 11:40 AM
red2bunkeru
Nov 12, 2009 01:23 PM
70GTX
Feb 20, 2008 04:16 PM
red2bunkeru
Feb 11, 2008 12:52 PM
