why was teh idler arm redesigned?
Old Dec 7, 2014 | 08:27 PM
mikerp76's Avatar
the idler arm on my 67 valiant went south on me. and while i was at work i happened to look up an idler arm for a 68 valiant and it's totally different. and so is the 66 model. was the k frame redesigned as well or can i use the a 68 idler in place of the 67 idler with out any issues?
Old Dec 7, 2014 | 11:19 PM
There were changes to the frame. I would guess the frame could be modified to accept the later Idler & the drag link changed. One enters from the top & one from the bottom ????
Old Dec 8, 2014 | 08:03 AM
DDodger's Avatar
67 A body was a "one year" deal. You can add an ear to the 67 K frame and use a 68-72 idler. 73 and later was different again as they reversed the centerlink stud All the idlers from 68 onwards used a "through" bolt and nut, where the 67 was stud mounted. All idlers from 68 onwards will fit the 68 and later K member. Again, the difference between the 68--72 group and the 72 / later group is the "up or down" of the stud on the centerlink.
There's a lot of good info and Moog part numbers on the tech pages at BigBlockDart.com
I'm not sure how to go about modding your K member without a sample to get dimensions off of.
Old Dec 8, 2014 | 06:34 PM
mikerp76's Avatar
thanks for the info guys. looks like i have some research to do. luckily the one i have is under warranty. was there a reason why they redesigned it?
Old Dec 9, 2014 | 07:43 AM
DDodger's Avatar
The 68/ later is far far superior. Much more support there at the frame, and better bearing.
shovel55
Nov 15, 2011 04:51 AM
jar84203
Apr 25, 2011 12:28 AM
recondotexas
Feb 6, 2010 10:39 AM
edbobx
Jan 29, 2008 05:22 PM
HPT Magazine
Jan 15, 2008 03:16 PM
