1970 challenger rt ignition problem
Old May 18, 2013 | 08:23 AM
1070rt's Avatar
got a 1970 challenger rt with a 440 six pack and it had electronic ignition but it was all wired wrong so I changed it over to points ignition, just wondering how do I go about doing this, not sure how to set it up and help is appreciated!
Old May 18, 2013 | 11:48 AM
knahavasu's Avatar
Best thing I did and would advise is get a good manual with electrical wiring schematics. That way you know exactly what goes where. If you have the bucks go but the correct harness for your application
Old May 18, 2013 | 04:17 PM
1070rt's Avatar
I must have worded it wrong I have the harness and its wired correct its the points inside the distributor cause its dual points and idk how to set them up to be timed right, I have the timing set with a timing right its the points inside that are off
Old May 19, 2013 | 10:52 AM
pro-tech's Avatar
Set the points at .017" on the high point of the dist. lobe. make sure there is a little dab of grease on the leeward side of the lever/lobe contact point
djmaster219
Feb 10, 2014 07:24 PM
Plymth74Dstr
Dec 21, 2013 07:17 AM
a.johansson84
May 27, 2012 03:30 AM
Tiretrack
Jul 10, 2010 08:14 PM
GMdude
Jul 9, 2009 04:42 PM
