1976 Plymouth Valiant Dash Wiring
Old Mar 1, 2019 | 12:32 AM
Donovan's Avatar
I have a 1976 Plymouth Valiant in which I have no Dash Lights this includes the lighting for the Heater/ AC controls and Gear Indicator, No working Gauges. I've Looked online for a Schematic for Just the Dash area. Does anyone Have something like that or can tell me if I'm missing a common Ground, Power, or Fuse? I forget what the (Lack of better word) Capacitor Looking thing on the back of the Dash is called and what the Long Silver Rectangle thing is.
Old Mar 1, 2019 | 11:11 AM
You check all the fuses?
Old Mar 1, 2019 | 01:10 PM
Donovan's Avatar
I have checked all Known Glass Fuses beside the park brake lever all fuses good.
Old Mar 2, 2019 | 07:25 PM
Got power out of the Headlight switch when turned on?
Old Mar 10, 2019 | 10:52 AM
Donovan's Avatar
Sorry took so long to get back new work schedule.
I took the dash back apart to test the switch. Getting power out. Should be noted that old headlight switch was changed.
Old Mar 10, 2019 | 12:33 PM
OK... I'm having some trouble finding the wiring info... What color is going to the dimmer adjuster on the headlight switch?
Old Mar 10, 2019 | 01:14 PM
Donovan's Avatar
Here is the Schematic I'm looking at. I didn't see the connection to the dash from the Headlight switch.
Old Mar 10, 2019 | 04:32 PM
Your looking for the same one that I was looking for...
Being that we dont have that one..... The switch has a dimmer in the switch... When using your test light. Dose the Dimmer have output? Going from brighter to bimmer when you turn the **** with your test light attached?
What we are looking for is to make sure we have the output and a starting color for the wires for the lighting.
The reason I think it is a power issue is... The ashtray light is housing grounded along with the heater control light, so we need to know if these have a broken wire at a splice or if we are just chasing a ground issue?
However, these wires can change color as you see in the wiring diagram. So we test and get out of the way what is known Good and move on...
Old Mar 16, 2019 | 05:15 PM
Donovan's Avatar
Before I start on Sunday I wanted to let you see these I just got through doing Schematic A has wining color through out a and b.
Old Mar 16, 2019 | 05:27 PM
I understand... When you get started... Follow the power.. I if that is good. Chase the ground... Make sure the dash reistat is on bright..
Kahuna
Mar 24, 2017 06:53 PM
Shrug
Apr 14, 2013 02:26 PM
DanK
Feb 10, 2013 09:20 AM
NANNERPIEZ
Sep 15, 2010 02:48 PM
65AzBel
Feb 4, 2009 11:31 AM
