2009 town and country drivers window switches
Old Dec 12, 2021 | 08:25 AM
Chargerdon's Avatar
On my 2009 Town and Country the drivers Window/lock/mirrors control panel no longer works. The door lock still works from the remote or the lock switch on the passenger door, but not from the drivers. None of the controls on the drivers door switches work. All other windows work from the switches on them. Tried replacing the switch panel as a new one is only $28 but still no work. It is interesting to note that that switch panel despite controlling all four windows, lock/unlock, and the remote power mirrors only has 3 wires going to it. Is there a relay somewhere else that could be bad ? Anyone else have this problem and solved it ?
Old Dec 12, 2021 | 01:56 PM
Switch connections, other conectors in the door especially the front of the door where it plugs into the door jam, broken wires in the door jam area. Plsy with the wiring while flipping the switch and see if movement in the wires doesn't get something going.
Old Dec 14, 2021 | 05:31 AM
Chargerdon's Avatar
After taking off the door panel I could see that all of the wires looked good. Nothing obvious but that in addition to the wires, there was a "control box" in the door above the speaker. It had the wiring that went to the switch and in total had 4 plug in wiring connections. I could tell that the thickest gauge red wire was probably the power source from the car and was able to put a multi-meter on it and ground and there was full battery voltage... So its part #dm-fl 42859c. Google search listed it as window control ECU and no longer available as a new part. So called several local salvage yards and found one in another 2009 Town and Country... Paid $50 Put it into the car and it fixed the problem !!! Note: In searching for the part i found that with slight changes to its part number 05026809ac last three digits this part apparently in in MOST of the Chrysler vehicle from 2008 up to 2015 that have 4 windows...prices range from a low of $30 used thru $144 used, and as high as $344 new . ..
Old Dec 14, 2021 | 09:37 AM
Nice.... Glad to hear you got it fixed and are back in action !!!!
csmith694
Oct 25, 2020 09:10 AM
98 SNAKE EATER
Apr 11, 2013 06:12 PM
DusterDude88
Apr 30, 2012 08:05 PM
Perarne
Feb 1, 2012 01:13 PM
staledog
Nov 25, 2010 06:53 AM
