'69 318 plug not firing - weird
Old Sep 28, 2018 | 01:30 PM
cuda341's Avatar
Hi Folks!
Gotta weird thing going on with this old 318 where #3 plug is not firing. Replaced plug with new, wire with new (and swapped with another working wire from same engine) and cap and rotor for good measure. Still no spark for #3. What the heck else could it be???
S.
Old Sep 28, 2018 | 07:31 PM
Archer's Avatar
S -
What kind of ignition, points or electronic?
If you put a timing light on the #3 wire, does it strobe?
IOWs, how do you know it's not firing? Sorry, have to ask.
IF, everything you said is true, the on the only explanation is a lack of plug ground, which is nearly impossible or a short upstream of the plug. My guess is you're missing something more obvious.
Yeah, that's a weird one.
Old Sep 28, 2018 | 09:15 PM
have you checked the compression on #3
Old Sep 29, 2018 | 06:04 AM
cuda341's Avatar
Originally Posted by Archer
S -
Yes on timing light...#3 is dark, but it would need a complete circuit to light, correct? Ignition is points with original distributor BTW. Tried a new plug as well. Puzzling.
Old Sep 29, 2018 | 06:08 AM
cuda341's Avatar
How would compression impact spark firing or not?
Old Sep 29, 2018 | 05:41 PM
Archer's Avatar
S -
You're going to have to break it down component by component.
Pull the plug and wire and set up an artificial ground (wire around the threads of the plug to a ground ) and look for spark.
Replace the plug with a ground wire to a chassis/block ground and check again with a strobe.
If there's no strobe on the wire, with the pick up at the dist cap, make sure the rotor is actually contacting the #3 terminal in the cap. Replace the points and condenser.
While unlikely, borrow another distributor and try it.
If all else fails, upgrade to an electronic ignition, they are pretty cheap and work really well.
Oh, was the 318 always this way, or this just start happening?
What else was done around the same time it started.
Again, think ground short. Start the engine at night and look for arcing.
Sorry, this is one of those "you have to figure it out" things.
Old Oct 17, 2018 | 02:04 PM
cuda341's Avatar
Solved it with a new electronic ignition kit.
Thanks all. Put in a new Proform MoPar EI kit which brought it back from a V7 to a V8 in minutes ;-)
Old Oct 18, 2018 | 06:14 AM
Archer's Avatar
S -
Glad it's fixed. Weird though.
My experience with ECUs, it that they either work, work intermittently or just don't.
Old Oct 18, 2018 | 07:14 AM
cuda341's Avatar
Well to be clear, there wasn't an ECU. Remember, this was an original points/condenser setup that we now have replaced with an electronic setup. Who knows when was the last time the points were serviced...probably over 20 years / 40,000 miles ago... New cap/rotor/wires with only get you so far! :-)
RBuijs
Aug 2, 2019 12:01 PM
newto440
Apr 13, 2014 09:45 AM
RRinTN
Oct 18, 2012 02:37 AM
olibass1
Sep 1, 2011 08:20 AM
Nomadci
Jul 10, 2010 06:18 PM
