77 Tradesman Insrument Cluster Lamps
Hi again folks, I've been quiet for a while - finally found a bush for my steering column and got it reinstalled. The original column switch wiring had been cut, twisted and taped! Not the best - so I used crimped bullet connectors, a much neater job. Please note the connectors need to staggered to enable the cowling to sit nicely.
Anyway, after doing all that I noticed my lh blinker on the dash wasn't working and so removed the dash and found 4 bulbs blown, the cluster push in types. What I wanted to know is what each of the bulbs do? I get the blinkers, the high beam at the top, but what do the rest do? I also have a bulb - loose on a long wire, which tells me I'm in park or neutral, whereabouts should that be on the cluster?
All replies greatly appreciated.
Timbo.
Timbo.
