Fusebox diagram?
Old Sep 22, 2013 | 12:27 PM
josehf34's Avatar
Fusebox diagram?
Hi everybody!
I've a little trouble with my fuse box. Yesterday I change all the fuses as preventive maintenance but now my fuel gauge, turn lights and reverse light stop working. sometimes when I touch the fuses the fuel gauge work again so I think the problem is in the fuse box.
Does anybody has the fuse box diagram for a Plymouth Fury 1974?
Thank you!
Old Sep 22, 2013 | 12:41 PM
moe7404's Avatar
sounds like a bad connection in the fuse box. i had to wire around a fuse box on 1977 D100 for the heater system. that and the A/C system take a LOT of amps. on a 1982 D250 i set up a relay for the A/C system. it was burning out the igntion switch.
Old Sep 22, 2013 | 12:49 PM
josehf34's Avatar
I've the same problem with the A/C system, if I turn it on the 30A fuse blows when the fan starts to work
Old Sep 22, 2013 | 05:27 PM
moe7404's Avatar
just use the a relay ( headlite relay) driven by the A / C connection, on the ignition switch. so the load goes through the relay, not the ignition switch. took me most of the day to get it done. tons of diagrams on the internet. go to advance auto and get a dorman crimper 86263. this is THE crimper. saves having to solder.
Old Sep 22, 2013 | 10:13 PM
Silverick's Avatar
Give this a try....
https://www.google.com/search?q=1974...&bih=687&dpr=1
Gishman91
Nov 17, 2022 01:43 PM
eklectictaste
Feb 28, 2012 01:59 PM
BuckNeccid
Nov 28, 2009 05:37 AM
Uber-Charged
Nov 26, 2007 04:03 PM
burnsy26
Oct 1, 2007 01:35 PM
