Head lights not working
Old Sep 9, 2023 | 11:38 AM
musky's Avatar
Question Head lights not working
i got a 2017 challenger 3.6 l My high and low beams are out.The day time lights work which i assume are the rings around the headlites but the headlights do not come on at nite any ideas on this?
Old Sep 9, 2023 | 06:03 PM
Not even manually?
Old Sep 10, 2023 | 05:42 AM
musky's Avatar
no and im not sure if i have hid headlights because each fuse box location i see it shows 2 yellow 20 amp fuses next to each other and i dont have those two.
Old Sep 10, 2023 | 07:51 AM
Check the bulbs..... One style has the later model Standard looking style bulb similar to a 9004...
The HID's : Some have a square box hanging off the back of the bulb...
Check for power at the connectors with the light switch in the on position...
Old Sep 10, 2023 | 09:53 AM
Kuvasz101's Avatar
Yup, I was just going to suggest bulbs but Racerhog beat me to it. I recall replacing and doing all kinds of stuff on a Dodge van with no low or high beanms only to find out they blew out when the customer hit a pothole.
Old Sep 13, 2023 | 01:37 PM
I would verify the high/low beam switch, in the older cars low beam goes out when bad not sure about this but I would check it out.
Old Sep 30, 2023 | 01:59 PM
musky's Avatar
would 1 blow headlite bulb make the other dead too, im asuming not?
Old Sep 30, 2023 | 02:56 PM
Kuvasz101's Avatar
No
Old Oct 1, 2023 | 11:37 AM
musky's Avatar
i dont have those 2 yellow 20 amp fuses for hiv headlites i also dont have relays 46 and 65 so im lost now.
Old Oct 1, 2023 | 03:38 PM
Check the headlight ballast.... Maybe they are losing power when they warm up????
Old Oct 4, 2023 | 01:45 PM
Lostviking's Avatar
I owned a 17 Challenger SXT also. Check fuse #15 and #15.
Old Oct 10, 2023 | 03:57 PM
musky's Avatar
im told the 2 fuses 40 amp in the trunk , to check those but they look like square little fuses, not the normal type what kind are they.
Old Oct 10, 2023 | 03:58 PM
musky's Avatar
under the hood or in the truck, this car does not have -h-i-d.
lmader
Jul 8, 2022 12:52 PM
MetalRims
Nov 8, 2017 05:51 AM
TRAMO
Aug 3, 2013 11:59 AM
bfcat9775
Jul 6, 2011 08:38 AM
muggsy
Nov 11, 2008 02:01 PM
