Headlights 66 New Yorker
Old Apr 12, 2012 | 09:01 PM
zberg's Avatar
Question Headlights 66 New Yorker
First off I am very new to the idea of using a forum but thought I would give it a try anyway. Two days ago I noticed when I turned the headlights on there would be a dip towards the D on the guage labeled alternator. Normally it settles in the middle all the time may fluctuate a little bit when using the power seats but has always returned to the middle. Tonight while driving the headlights shut off completely, the high beams still worked and after pushing them on and then off the headlights were back but after about 5-10 minutes went out again. The high beams remain working and also the tail lights remain lit. Any ideas or suggestions greatly appreciated.
Old Apr 13, 2012 | 07:52 AM
There are several areas of concern that applies to ALL older Mopars
The bulkhead connector may be corroded/ loose/ heat damaged, especially the main battery feed and the charging lead from the alternator
The alternator may or may not be putting out full output, or---
if you have upgraded to Halogen headlights, they draw more current than original
Older Mopar alternators are not known for good performance at low RPM
The headlight switch, connector, and dimmer switch and connector may have problems
The high and low beam feeds through the bulkhead may be less than good
And the connections "up front" at the headlights and headlight grounds may be less than stellar
AND headlight switches have a circuit breaker built in which can become weak over the years.
PLEASE read this excellent article from "MAD electrical:"
which came from here
Look especially at the diagram posted in that article.
Notice on the black lead on the ammeter the "welded splice?" This is a big factory splice taped up in the harness under the dash. This comes right off the ammeter circuit and supplies UNfused power direct to the headlight switch, ignition switch, and a couple of other places
NOTE that the HEADLIGHT feed goes through the breaker ON (in) the headlight switch THIS CIRCUIT ONLY powers the headlights, NOT the park/ tail or instrument lamps
So you light switch has THREE separate circuits
ONLY the headlights on one circuit
The TAIL PARK lights on the second supplied from a fuse in the panel
ALSO powered from the TAIL circuit is the DASH LIGHT DIMMER circuit. NOTE that the power for the dash / instrument lamps comes OUT of the light switch dimmer control, and THEN goes to a separate small fuse in the fuse box. THIS IS the only circuit wired this way, IE fused after a switch.
So to sum up:
You may have a damaged alternator, IE one bad diode, etc
You may need a larger alternator
You PROBABLY need to address some of the wiring concerns above
You would do WELL to consider installing headlight relays under the hood which takes the load off the headlight switch, the dimmer switch, and the bulkhead connections
Old Apr 13, 2012 | 12:07 PM
zberg's Avatar
Thank you for the advice now I have a starting point.
Old Apr 13, 2012 | 05:22 PM
Post back when you get deeper into things. You have a wiring diagram/ service manual?
durangogirl
Dec 11, 2012 09:25 AM
440lives
Dec 5, 2009 08:37 PM
cjperry81
Mar 18, 2009 05:23 PM
mahd
Feb 25, 2009 12:02 AM
skymynx
Nov 17, 2008 09:11 AM
