Horn Relay Location
Old 08-26-2013 | 10:18 PM
MilesP's Avatar
Horn Relay Location
Hi,
In my '72 Polara Custom, the horn doesn't work. I connected both "trumpets" directly to the battery, and they function properly. Pushing on the wheel doesn't do anything, and I can't even hear a click from the relay.
Now I took the bottom part of the dash off, and looked at anyting that could resemble this, if this is even correct for 1972 (I don't know the exact part):
All I found was A/C blower relay, light delayer, flashers etc.
But I cannot find that darn metal box. The previous owner did tinker with the electrical, and I suspect he removed the relay and never put it back. Problem is for my car model and year, I'm not sure where that relay is located in the first place, and what's the correct prong pattern if I can find an empty connector.
Also, I looked at this, and that, nowhere does it shows the horn steering switch or relay. the dark-green red wire just gets lost.
Can anyone shine a light here?
Thanks!
Old 08-27-2013 | 07:21 AM
Look behind the Drivers Kick Panel.... As far as I remember their are only 3 wire.
Old 08-27-2013 | 09:44 AM
Here, drop by FABO and download this factory (but Plymouth) shop manual for 72
http://www.forabodiesonly.com/mopar/...p?p=1970088617
All it says as to location (page 8-91) is "located under instrument panel on left pad or on fuse block"
Wiring diagrams start page 8-144, I'd guess Fury would be the same as your Dodge
So that's page 8-168 and it appears to me that it plugs into the fuse panel, and is indeed 4 terminals. This would be a combined horn relay and key buzzer. That is evidently why the diagrams you posted show it up by the fuses
H3-20BK coming in from the top comes in from your horn button and essentially grounds that terminal
H2-16 DGN/R goes out on pin 20 of the bulkhead connector
The violet picks up battery power
Pin 4 at far left goes to M16-20BK and is the key-in warning buzzer
The following 2 users liked this post by 440roadrunner:
MilesP (08-27-2013), RacerHog (08-27-2013)
Old 08-27-2013 | 04:29 PM
MilesP's Avatar
Beautiful, thank you!
I've attached a shot I took of my fuse box: Compared it to the manual you provided, mine looks reverted, (right column, diagram is left) but the prong pattern seems to be the same.
So the relay would go into the 4 prongs that are to the top right of my fuse box. The other two terminals are empty.
So then, I'm assuming something like this or that works?
Old 08-27-2013 | 05:23 PM
440 Roadrunner... is the man !!!! Winner...Winner...Chicken Dinner !!!!
Oh...The horn fuse is still good.... Don't need to check that one....
Heater and A/C might be a different story....
Old 09-09-2013 | 01:11 PM
MilesP's Avatar
Update: I've received the relay (same as one pictured in my post above) and plugged it in the fuse box, and voila! Horn works, and so does the creepy key buzzer.
Thanks again guys!
RacerHog (09-09-2013)
dgbcharger
07-28-2015 04:37 PM
blazo
06-10-2012 10:56 PM
mach3107
02-08-2011 08:42 AM
sgp7679
08-25-2009 05:44 AM
zdizzle85
03-09-2009 09:21 AM
