I've got turn signals and tailights, but no brake lights.
Old Sep 11, 2012 | 05:20 PM
77Adventurer's Avatar
Just like the title says, I have no brake lights on my '77 D150 Adventurer. I have turn signals and when I turn the headlights on, the tailights come on as well. But when I step on the brake pedal, no brake lights! I am at a loss as to what this could be. Any ideas?
Old Sep 11, 2012 | 05:54 PM
mikerp76's Avatar
have you checked your brakelight switch?
Old Sep 11, 2012 | 06:25 PM
X2. It's mounted on little bracket right above the brake pedal.
Old Sep 11, 2012 | 08:19 PM
Brakelights go through the turn signal switch. If you have power out of the brake light switch when you step on the brake, you have a bad column switch
Old Sep 15, 2012 | 08:01 PM
Hey, I never thought of that! Great idea!
Old Sep 22, 2012 | 02:55 PM
Since I don't have hazzards or brake lights, it makes sense that the turn signal mechanism is bad. I have the turn signal cam, but its the part that the cam bolts to that has the hazzard switch on it. I have the steering wheel off, and I can see a whole bunch of wires coming out of that turn signal mechanism. If I can locate a new mechanism, how hard is it to replace it, having to cut all those wires and splice them into the new part?
Old Sep 23, 2012 | 05:48 PM
Hey, my dad had an idea regarding the problem last night. I thought I'd run it by you guys to see what you think.
He's thinking it may just be as simple as the turn signal relay/flasher unit on the fuse panel. Does this sound possible? It would sure be a whole lot easier and cheaper than trying to find a whole turn signal mechanism.
Old Sep 23, 2012 | 07:14 PM
Fedge1369's Avatar
the quick way to check is swap the turn signal and hazard flashers...if you lose the turn signals, but get your hazards, then yeah, the flasher is no good
Old Sep 24, 2012 | 07:34 PM
Got the turn signals and hazzards working. Still no brake lights. Checked for power at brake light switch. It has power to one of the two spade connectors, and no power to the other spade or the big plug at the end of the two wires. Is this the way it's supposed to do? Is the brake switch shot?
My dad thinks that maybe the other spade has power to it when the switch is operational, thus the big plug would have power as well. Does this sound correct?
Old Sep 24, 2012 | 08:06 PM
My diagram has power from fuse to brake switch, out of brake switch to flasher, flasher to turn signal switch, from signal switch to firewall connector, connector to lights.
Jumping brake switch should turn lights on.
Old Sep 24, 2012 | 08:59 PM
Fedge1369's Avatar
+1
Old Sep 25, 2012 | 10:49 AM
You ARE checking this power at the switch with the pedal depressed, right?
If you are, you have found the problem--a bad brake switch
lifted150
Apr 8, 2022 07:09 PM
Max Mayhem
Jul 23, 2014 07:54 AM
JP67
Aug 17, 2012 07:34 PM
67Polara
Jun 8, 2009 05:53 PM
johnnyc
Mar 4, 2008 06:13 AM
