In need of Assistance..Ron Francis Wiring Kit?
Old Aug 18, 2011 | 12:21 AM
Razoreyes45k's Avatar
Hi,
I'm wondering if anyone has installed a Ron Francis Wiring kit for their Mopar. I own a 1977 Dodge Tradesman B200 Van which has thenew "Access 24/7" Wiring Package. My problem centers on the Ron Francis wiring to the NS (Nuetral Safety) Switch. I've followed the instructions in the kit and I have NO Ignition..... Engine will not crank. I've already spoke to "Larry", a technicion with the RF tech. dept. and explained everything to him. So far, his help has not netted me a positive result. If anyone has experience with this particular set-up, I'd like to hear.
Chris
Old Aug 18, 2011 | 08:59 AM
Unfortunately, little Ronnie chooses not to make destruction manuals available for download
The NSS wiring should be no different than factory. Basically, you have a starter relay with two push-on terminals. Either one of those is connected to the 'start' signal coming from the ign switch, and the relay turns on when the second push on terminal gets ground through the NSS switch. So the second push on terminal goes down over the top of the transmission to the CENTER terminal of the NSS switch
All you have to do, then, is take a test lamp and check the following:
Check that one of the push on connectors is "hot" when you twist the key to start.
If so, check the other push on going to the NSS for voltage in start. There should be NONE. If there is, either the wire is bad, the NSS is not making contact, or the transmission linkage is not getting the trans into park/ neutral
If you have juice from the key, none at the second terminal (NSS side) and the relay won't engage, you probably have a bad relay.
Unhook the NSS, clip lead that terminal to ground.
Unhook the key (start) lead, and jumper that terminal to known hot battery terminal. IF the relay doesn't work, well then..... you've found er.
Pana-Yamithis
Jun 15, 2014 07:19 PM
tjstiles
Dec 1, 2009 10:45 PM
cyclone2321
Aug 2, 2009 08:25 PM
alsparl
Jul 7, 2009 03:39 AM
1970ChallengerSE
Mar 16, 2007 10:20 AM
