Power window wiring weirdness
Old Jul 2, 2017 | 10:04 AM
willem_at_work's Avatar
Hi,
I have a '72 Dodge Coronet Custom Wagon with a problem in the power windows. It has 4 power windows that only work when i hotwire the power lead. I have been able to trace the cable for the power to a relay that's attached to the main fuse box (see picture). This relay doesnt give power... I think it's the horn relay? I can hear it switch whenever i press the horn. Also, when i make it switch by putting power on the blue/white lead, the power windows do work.
Does anybody know what's going on here?
I have enclosed a picture of the relay. Its the one hanging below the fuse box with the thick red wire.
regards. Willem
Old Jul 2, 2017 | 08:23 PM
Where dose the Blue wire with the white tracer go?
Old Jul 3, 2017 | 02:01 AM
I have been able to trace that one to a Relay inside the dash and a connector under the seats. The Relay has the number 3588588 36033
Old Jul 3, 2017 | 09:46 AM
Well, i did some research, and i think this relay is the seatbelt relay as seen in the diagram in this thread
http://www.dodgecharger.com/forum/in...?topic=35163.0
this is a diagram of a 73, where mine is a 72. I do have more or less the same wiring i think, but i have a seperate horn relay with a lightbrown/tan wire going to the power windows (number on the relay is 2926433). Does that make any sence?
Old Jul 3, 2017 | 02:08 PM
The Tan Wire should be the (+Hot) Check to see if you got power to that wire?
If the tan wire has power, Then the power window safety interlock switch is turned on or is bad....
Is so, Check the yellow wire and see if you have power?
The window lock switch is between the tan and the yellow.
Old Jul 3, 2017 | 02:27 PM
thanks Bob!
well, the Tan wire that's leading to the windows doesn;t have power. Which yellow wire should i check?
Old Jul 3, 2017 | 07:22 PM
Ahhhh... Ok... If the tan dose not have power. then the yellow that ties all the switches will not work. I dont recall where the source wire is picking up power.
Trace that wire (Tan) back to the power source.
And then get back to us...
Old Jul 3, 2017 | 11:03 PM
Hi Bob,
The Tan wire's source is (i think) the horn (?) relay in the first picture. I don't know if this is true, but i think the red wire that goes into this relay would be the power source for the Tan wire?
I have been experimenting a bit: When i put a current on the top blue wire of the same relay, i can hear it click. When i leave power on this blue wire, then the windows work. Funny thing is that this blue wire leads to connectors below the seats (/belts)
Old Jul 4, 2017 | 10:39 AM
Ok. So if that the case???
Dose the blue wire have power coming out of the ignition switch? Should be the same color Blue wire?
Old Jul 4, 2017 | 11:00 PM
ok, i'll check that. thanks Bob!
i'll be posting a result in a couple of days
Old Jul 9, 2017 | 11:14 PM
Hi Bob,
I did as you told me and found a wire with the same colour code (as the one from the relay) coming from the steering column. I traced that all the way back to the fuse box and guess what... between this wire and the wire from the relay i found a fuse
replacing the fuse fixed my problem.... thanks for your help!!!
Old Jul 10, 2017 | 09:35 PM
Awesome..... Thanks for the up date.... Sure glad it was something simple...
sarahbearmuffin
Jul 21, 2011 09:15 PM
ctrain22
Aug 27, 2010 06:06 PM
66300convertible
Dec 24, 2009 04:56 AM
clombardo66
Jun 25, 2009 07:18 PM
clombardo66
Jun 10, 2009 03:24 PM
