Starter failure
Starter failure
Guys... I just completed a Magnum engine swap on my 86 W250. The starter off the magnum motor worked flawlessly when I pulled it... I even used it on the old LA 360 for a while first. Now I have the Magnum in and almost all buttoned up, I was going to try to turn it over just for fun and all I got was a solenoid click. Now I know all too well what that one click typically means (starter motor going bad) but I mean it was literally flawless function when removed. It sat on my shop table for 3 months and then I reinstalled it and bam... it no worky. So I guess my question is before I go trading it in for a core charge on a new are there some possibilities? I had the thought that perhaps it was a ground issue? I didn't really pay attention to where the ground was bolted to the Magnum before removal. Will any bolt hole do or does it need to be specifically grounded to the block itself (not with an accessory bolt) I think the spot I chose actually bolts through the aluminum accessory bracket into the heads. I used my handy multimeter and I have a solid 12.3v potential at the starter. Anyway just trying to avoid pulling starter and having it tested unnecessarily. Any help would be appreciated.
Is the Battery fully charged??? starter dont just go bad sitting on the bench...Check all the wires + & -...You could try tapping on the starter but you didnt hear that from me...Be gentle and only as a last resort....You can ruin the starter by hitting it because of the ceramic magnets in them...Keep Us posted...Bill
First I bench tested the starter with a jump box and some creative thinking. I found that there was so much build up on the face of the starter it wasn't making good connection. Cleaned surface with a wire wheel, put her back on replaced the ground wire because it was suspect anyway and she turned right over. Thanks for all the suggestions guys. Got me thinking and got it resolved!
NO you were saying feed wire...I have never heard of the face of the stater being dirty causing that....I would think as you tighten the bolts it would make a ground unless the star washers are missing...Bill
GLAD YOU GOT IT FIXED!!!!!!!!!!!!!
Trust me it blew my mind too... yes the washers with the teeth are missing.
sgoffena
Nov 9, 2007 07:55 PM
