Turn Signals Defective 05' Grand Caravan (Dodge)
Old Dec 14, 2023 | 01:51 PM
TheDodgeGuuy's Avatar
Hi there I have an '05 Grand Caravan and the turn signals are all messed up any help would be very much appreciated.
Issue:Signal Left turns on the right signal, signal right turns on right, with Switch in the middle position (off) the right signal turns on. With interior lights all the way up (rear interior lights on only) the turn signals shutoff. go down one notch the left turns on. anywhere in-between off and second notch the right signal turns on.
My battery did end up dying and never had the same charge again. Had to boost multiple times. but alternator is good.
Parts Replaced: Front Control Module (FCM), Multifunction Switch/Turn Switch, Headlight/Interior Light Switch, Bulbs
Tried Fixes: Inspect remote start wiring, grounds with continuity test, cleaned contact on bulbs and sockets.
I can turn all signals on with hazards though.
Thanks In Advance
VIDEO DIAGNOSTIC (Had to upload to YouTube)
Old Dec 14, 2023 | 04:44 PM
Faulty battery so start with.. No power drives the electrical system nuts...
Old Jan 30, 2025 | 10:36 AM
sallyrenme01's Avatar
Take a known good bulb from the other side and swap them, if the bad turn signal now lights up, replace the bulb. If it doesn't light up, you'll check for good power and ground at the socket, if you don't have one or both, then you'll cسheck your fuses and wiring harness for dam
Old Feb 1, 2025 | 11:01 AM
Another thing that really helps mess up vehicles electrical systems is good grounds and you need to be on the lookout for loose electrical connections and electrical wires that have been chewed up by rodents. I have a family member that just sold a low mileage Chrysler mini van because of this. So when you do your bulb swap look for evidence of damage from rodents and other problems.
Drew1963
Aug 9, 2023 05:13 AM
vroc4507
Oct 1, 2022 07:06 AM
crwchf16
Jan 22, 2018 08:55 AM
chykov's76doba
Oct 29, 2014 03:08 PM
nesparky
Dec 12, 2011 07:05 PM
