turn signals and flashers????
Old Aug 16, 2022 | 04:25 PM
vroc4507's Avatar
I've been getting frustrated with the right turn signal on my '67 Coronet. When I lift the turn signal lever to indicate a right turn, the dash light comes on as well as both front and rear signal lamps but they will not flash. When I push the signal lever down to indicate a left turn the lamps flash correctly. When I flip on the hazard switch, all 4 lamps flash correctly.
Could on of you fine folks help shed some light on this issue?? Thanks in advance!!
BK
Old Aug 17, 2022 | 07:40 AM
Archer's Avatar
BK -
Sounds like a short in the flasher control switch in the steering column.
But could be a short anywhere downstream as well.
Old Aug 17, 2022 | 10:15 AM
vroc4507's Avatar
Originally Posted by Archer
BK -
That's where I'll start then. Thank you so much!!
BK
Old Sep 27, 2022 | 07:37 AM
geekandson's Avatar
I am having a similar problem. When I turn the lights on the right turn signal lights up. This is with the key off....Also the right blinker blink both tail lights when the lights are off
Old Oct 1, 2022 | 07:06 AM
I think Vroc has a bad turn signal flasher or Turn Signal Switch>>>>>>
And I think Geekand son has a bad Turn Signal switch and a ground issue to handle.
crwchf16
Jan 22, 2018 08:55 AM
Red440RT!
Jul 5, 2016 06:19 AM
chykov's76doba
Oct 29, 2014 03:08 PM
nesparky
Dec 12, 2011 07:05 PM
Bcrusep86
Oct 27, 2011 12:37 PM
