Voltage regulator
Old Mar 9, 2014 | 07:46 AM
1968newport's Avatar
Voltage regulator
Do I need to retain my voltage regulator despite changing my ignition system to msd, and will be changing out my alternator to a 150 amp model? New wiring harness is being used.
Old Mar 9, 2014 | 07:48 AM
Depends on what kind of alternator your running. You better bypass your amp gauge cause those kind of amps will burn it up.
Old Mar 9, 2014 | 09:16 AM
The above. Depends on whether you buy, say, an aftermarket alternator with a built in (integral) regulator. ALL alternators use regulators, it's just that some are built in. On late model Mopars they are built into the engine computer (EFI)
Also, what makes you think you need a 150A alternator?
Please read this article:
on the problems with original wiring harnesses, ammeters, and bulkhead connectors
Old Mar 12, 2014 | 05:09 PM
I am running many electric accessories including a sound system. Electric water pump, cooling fan, electric tranny cooler with fan, dual fuel pumps, lights, interior power sources, gauges, etc. how big should I go? I just want to be sure that I am not going to have a dead battery when I get to where I'm going.
Old Mar 12, 2014 | 05:11 PM
How do I wore in my aftermarket ammeter?
Old Mar 12, 2014 | 06:21 PM
moe7404's Avatar
i think chrysler used 2-3 different AMP meters over the years. i think its best to go to a volt meter. seems that all car makers use volt meters. and seam to do the job fine. when it was cold this winter my volt meter seamed to make the bat volt a little higher you cant see that on an AMP meter.
Old Mar 13, 2014 | 06:03 PM
So with a voltmeter I don't have to worry about anything with using a 150 amp alternator?
Old Mar 13, 2014 | 06:49 PM
moparted's Avatar
the factory wiring cant handle 150 amps. you need to use relays to power hi draw items directly from the battery
Old Mar 13, 2014 | 10:28 PM
PLEASE read the link I provided earlier....................
Northerndave
Jul 20, 2010 07:25 AM
dodgenut7
May 1, 2010 06:36 AM
scott2683
Apr 18, 2010 07:57 PM
440Challenger
Aug 13, 2008 03:04 AM
71 GTX
Feb 20, 2008 08:07 AM
