Wire identification
Old Dec 29, 2016 | 04:46 PM
1970ccc's Avatar
Wire identification
I have a tan wire with a round plug that's unattached behind the instrument dimmer switch. It's about 4" long. Can someone tell me where it goes? It's a 1970 Belvedere. Also, my gauges don't work and all dash lights are out. I'm hoping the wire and my issue is connected. Also, I don't have voltage (with the ignition key on) on either side of the instrument panel light fuse. Thanks
Ron
Old Dec 30, 2016 | 07:51 AM
1970ccc's Avatar
I found another wire, same plug but with 2 tan wires by the ash tray. Are these for an unused option? Ignition and ash tray light?
Old Dec 30, 2016 | 09:54 AM
Dimmer switch or dash panel socket.... But yes it's for lighting...
Old Dec 30, 2016 | 03:32 PM
1970ccc's Avatar
Thanks. As for my dash lights issue, I don't have any power on either side of the fuse for the dash lights with the ignition on. All other fuses have power. I guess I could have a short between the ignition switch and the fuse. Would a bad dimmer switch cause the same issue?
Old Dec 30, 2016 | 03:52 PM
fivepoint's Avatar
See if you have power to the fuse with the light switch on.
Old Dec 30, 2016 | 04:00 PM
1970ccc's Avatar
Tried that too. No power on either side of fuse with either lights or parking lights on. I have noticed that my passenger brake light stays on all the time. Related? I have idiot lights and turn signal indicators working, but no dash lights or gauges work.
Old Dec 30, 2016 | 08:38 PM
I think the other side of the tan on the fuse block is Orange and gose back to the ignition switch.... Wire might be broke.... See it you get power out of the switch connector.
The rest might be a bad ground.
You got some chasing to do...
Old Jan 10, 2017 | 04:13 PM
1970ccc's Avatar
Update. I bought a powerprobe III and used it on the dash lights fuse. With the key on and lights on, I'm only getting 7volts. With the dimmer switch down, it's less than 1 v. With it up, it varies from 1 - 7 and is inconsistent. When I hit the fuse with 12v (powerprobe) the dash lights right up. Bad dimmer? If so, where's a good place to get a quality replacement?
Old Jan 10, 2017 | 07:12 PM
Could be a weak Dimmer Switch....
But the voltage sweep sounds rite, for the most part...
Here is some reading...
http://www.allpar.com/history/mopar/electrical2.html
And also:::: An LED swap...
http://www.forbbodiesonly.com/moparf...bs.8041/page-2
Old Jan 10, 2017 | 07:31 PM
1970ccc's Avatar
Thanks Bob. Since I have lights when I hit the fuse with 12v, can I add a jumper from a switched fuse over to the dash fuse? Source side of course. I don't care if the lights are always bright. Thoughts?
Ron
Old Jan 10, 2017 | 07:37 PM
You could do that. I'll call you Micky Mouse from here on out!!!! lol
Sounds like the other side of the fuse feed wire is having an issue... But you could run a new source wire, that should fix it????
Old Jan 19, 2017 | 01:10 PM
1970ccc's Avatar
Old Jan 19, 2017 | 01:16 PM
1970ccc's Avatar
Since I can add 12v to the fuse block and get all the dash lights to work, what would cause all 3 gauges (oil, temp, and fuel) to still not work? I replaced all harnesses on the engine side and the harness to the rear of the car. Is there something like a voltage regulator, capacitor, etc that would affect the gauges?
Ron
Old Jan 19, 2017 | 05:17 PM
Amp Gauge...
Did they ever work?
piratemike
Aug 16, 2008 04:57 PM
ramsterhemi
Jun 3, 2008 02:35 PM
tjoker336
May 24, 2008 09:02 PM
ccflash22
Nov 12, 2007 04:22 PM
bcuda65
Apr 26, 2007 04:38 PM
