Wiring For Pertronix Parts
Old Sep 2, 2022 | 02:47 PM
Mopar4Life90's Avatar
Hey guys, so before I go any further, I want to say that I do not have the best knowledge in wiring. With that being said, I have a ‘79 Dodge with an LA 318 that I installed a Hughes Whiplash cam along with Pertronix Digital HP Module, Pertronix Distributor FlameThrower II, and their FlameThrower II Coil. I have the wiring correct for the module to the distributor and coil. And I had the ignition wiring going to the “IGN ACC” fuse.
I have the power getting to the module and truck turns over but no spark.
I have the original ignition module (4 Pin) still hooked up and the dual ballast resistor. Is there any other wiring I’m missing? Is the ballast resistor not needed (which I’ve read)? Any help, or diagrams would be helpful. I’ll put the diagrams I found up that maybe could help all of us get on the same page.
Old Sep 3, 2022 | 08:56 AM
Check to make sure that you have 12 volt when crank the engine over on the Ign Acc .....
Old Apr 29, 2025 | 01:18 PM
sallyrenme01's Avatar
Get one from pull a part with same part # . They don't have to have the vin programmed like people say. I have swapped one and everything worked fine
192.168.100.1 192.168.1.1
Robin
Jun 23, 2020 10:32 AM
CaptBeach
Dec 28, 2013 10:54 AM
miserablebob
May 12, 2011 07:44 PM
will d
Dec 16, 2009 05:51 AM
Mixmastermerrill
Aug 14, 2008 01:36 PM
