Wonky speedo!
Old Apr 16, 2013 | 08:30 AM
Shrug's Avatar
Wonky speedo!
Is there any way to get my instrument cluster out without completely removing my sterring column?
The needle of my speedometer is stuck at 35 mph.
The speedo works, but you always have to subtract 35 from the number. Kinda annoying.
I tried pulling the cluster so I could take it apart, but the column will not drop far enough
Suggestions?
Old Apr 16, 2013 | 09:43 AM
You should be able to just unbolt the column floor plate and the dash bracket without actually removing it - just let the steering wheel rest on the seat
Old Apr 16, 2013 | 12:16 PM
Shrug's Avatar
D'OH! I forgot about the floor plate! Ok I got everything out. the steering wheel would not rest on the seat, but I got the column just low enough to get the gauge cluster out.
First thing I noticed, somebody messed with the speedo at some point. the screws were loose and it had clearly been opened.
I was easily able to reposition the needle at 0. Blew out the whole assembly with some air and put it all back together.
Also put the alternator gauge wires on properly, they were reversed.
Now my entire gauge cluster works perfectly.
The speedo bobs a little but I suspect I just have to clean and lube the cable in the housing.
Thanks again for your help. For the help of the whole board really. I do not know what I would do without you guys.
scotts74birds
May 17, 2010 06:50 PM
stazja01
Jun 2, 2009 05:45 PM
craveman
Mar 25, 2009 01:54 PM
65AzBel
Feb 10, 2009 01:30 AM
debby440
Jun 18, 2008 11:55 PM
