66 monaco lower door hinge(door won't stay open)
Old Mar 25, 2015 | 11:11 AM
labradorian70's Avatar
The passenger door on my 66 monaco convertible will not stay open. In the attached pics of the lower hinge you will notice the spring is not attached, it keeps coming unclipped from the lever. the lever moves freely and because the lack of tension the spring just won't stay on.
I reattached the spring and it made no difference. I can see that the roller is still in place. Is there anything missing? broken? or adjustments? I looked in the shop manual and don't see anything on this. the only thing i found in the manual is door diagram and is not detailed enough to show the components of the hinge.
thanks
EDIT: the drivers side door won't stay open either, i noticed the roller in the lower hinge is missing on that side. has anyone ever replaced this roller?
Attached Thumbnails 66 monaco  lower door hinge(door won't stay open)-2015-03-24-19.23.15.jpg   66 monaco  lower door hinge(door won't stay open)-2015-03-24-19.22.31.jpg
Old Mar 25, 2015 | 08:04 PM
Originally Posted by moparted
my guess is wrong spring
could be possible, i'll keep that in mind.
thanks
Old Mar 26, 2015 | 11:28 AM
Yellow makes me think Brake spring ?????
Old Mar 26, 2015 | 02:24 PM
the yellow you see is rust. but yes, is this the right spring is the question.
cheers
Old Mar 26, 2015 | 08:42 PM
With the door open there should be space between the spring coils to keep it open
Old Mar 29, 2015 | 04:54 AM
With the spring hooked up, opening the door puts no tension on the spring at all. there is a roller inside the hinge and im thinking it may not be turning and it may just been worn. that lever that the spring is attached to may have worn a groove in the roller. that is my thoughts.
i got a look at the drivers door and the roller is missing on that side and it does not stay open either.
has anyone ever replaced rollers in these hinges before?
Old Mar 29, 2015 | 04:59 AM
i spoke to my father(original owner) and he says he's never done anything with the door hinges other than lubricate them. said he never replaced any springs.
cheers
Polara-Lee
Nov 20, 2014 07:41 AM
Polara-Lee
Aug 4, 2013 08:14 PM
Firewoman
Feb 6, 2010 09:07 PM
moparcanblue
Jun 21, 2009 03:03 PM
StanH
Dec 15, 2008 08:35 PM
