Dodge A100 Van driveshaft needed
HI all, need a driveshaft for a 1967 Dodge A100 van. It is equipt with a slant six and a Torqueflite. that would be ideal if you ahve that driveshaft-or one froman application that is a bit longer that I could have shortened.
Thanks for your help!
Take a measurement from the rear end pinion flange to the seal on the output shaft of the transmission. That should get you where you need to go in length. them you guys can figure out the yoke and size u-Joints needed for the project.
At least you will have 3 prices and can make a good judgement call...
http://www.dtscustom.com/files/dts-d...order-form.jpg
Might check with>>>>>>> http://www.dodgeconnection.com/73_93...ruckparts.html
Or
http://www.dvap.com/
Or
