Dodge A100 Van driveshaft needed
Old Apr 30, 2018 | 08:13 AM
Sunracer's Avatar
HI all, need a driveshaft for a 1967 Dodge A100 van. It is equipt with a slant six and a Torqueflite. that would be ideal if you ahve that driveshaft-or one froman application that is a bit longer that I could have shortened.
Thanks for your help!
Old Apr 30, 2018 | 12:27 PM
https://www.iedls.com/
Old Apr 30, 2018 | 03:57 PM
Sunracer's Avatar
well I called them $500- if I could give them all the specs, but I havent got any driveshaft to use and the cost is way too rich for this project
Old Apr 30, 2018 | 04:29 PM
Stop in to the rear end shop on southfront road OR Bayshore truck and equipment on Vacso rd...
Take a measurement from the rear end pinion flange to the seal on the output shaft of the transmission. That should get you where you need to go in length. them you guys can figure out the yoke and size u-Joints needed for the project.
At least you will have 3 prices and can make a good judgement call...
http://www.dtscustom.com/files/dts-d...order-form.jpg
Old Apr 30, 2018 | 04:36 PM
Might check with>>>>>>> http://www.dodgeconnection.com/73_93...ruckparts.html
Or
http://www.dvap.com/
narooz
Mar 25, 2020 08:35 PM
treloarjeff
Oct 29, 2014 09:46 PM
aceofspades
Mar 19, 2014 09:10 PM
66 A100VAN
May 14, 2010 08:29 PM
aarcudaed
Oct 16, 2009 04:40 PM
